I just want to make sure im on the right path with a 07-09 GT500 the stock fuel pumps are being replaced with DW 340lph pumps. To tune the Voltage Table so far I found in the scanner for X and Y axis of the table and fuel pump actual voltage which should be everything to tune the table. Should I disable the adaptive learning for the voltage table while im logging or leave it on and I assume I may have to change the flow rate axis also. Any tips would be appreciated. Thanks
