How to dyno a 10 Jeep SRT8 w/ AWD
Is there a way to put one of these in 2wd to run on the dyno? I don't any experience with them and quoting a job at the moment.
Thanks for any input.
Jason
Remove transfer case motor and harness connecting it, under driver side, grey round looking thing with 4 10mm bolts. This is the easiest way, quick job.
If it is any thing like my 2012 awd charger, you can disable AWD in HP tuners. Under "system" tab and then "general" tab select "disable" in the AWD field
first gens you have to pull the t case motor like 06300CSRT8 said. Second gens can be disabled with the scanner
Thanks guys. I appreciate it
guys i have a 2005 dodge durango that have AWD 4LOCK 4LOW and i want the car to be 2 wheel drive so it do burnout how ? in hptuner AWD option is disable factory
For that 2005 Durango your only choice is I believe is mechanical, not via the tune. But I am not an expert in the Durango.
the quick and dirty way that we've done it, which is dangerous but , you block up the front end so the front wheels are free to spin, then get a flunky to hand spin the front tires while doing a dyno pull. this works on 2000-2006 and up mercedes benz and chryslers
LOL @ 'flunky'
