Results 1 to 10 of 10
Thread: Turbo 1LE LS3 Camaro Double Stoich Half IFR **Issues**
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    2014 1LE Camaro stock internal LS3 M6 single turbo
    Seeing the VE and Clyair go the wrong way twards ZERO under boost!!
    *see attached log @ 1.06
    I have done other turbo Camaros but I usually start with the 2bar os that this Cal does not have.
    ZL1 Map
    DW 90Lbs *double Stoich - Half IFR*
    stock pump and FPCM
    Can I use a proven E38 2SS Camaro OS and write entire to get a HPT 2bar OS on this ECU with out side effects?
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Your VE table looks totally stock. Update to 3.4 and view the virtual VE. Your table is going negative in those instances.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Tuning Addict
    Jan 2015
    6,804
    Just to clarify - this is what I see when I'm looking at your log - everything "appears" correct except where there's a lean spike from what appears to be you letting off?
    Is this what your seeing when you look at it?
    ~Greg Huggins~
    Mar 2006
    sunny So Cal
    292
    Actually I am steady at mid throttle!!!!
    look again
    http://www.hptuners.com/forum/attach...3&d=1485466330
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    Your VE table looks totally stock. Your table is going negative in those instances.
    I am seeing the calculated VE go form 1500 to under 300 in a tenth of a second
    while at half throttle under boost
    1900 is listed in the cells that situation references.
    Is there VE or MAF offsets that need to be confirmed?
    http://www.hptuners.com/forum/attach...4&d=1485466483
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    Is it safe to Write Entire a 2SS Camaro OS that supports the 2bar OS with boost referenced PE
    and not dork up anything on the E38 1LE
    BTW updated HPT to 3.4.054
    NotoriouSS TAD
    Mar 2008
    St. Louis, MO
    4,860
    Check your MAP sensor reading against your VVE labels... you aren't displaying the boost area at all.
    Mar 2006
    sunny So Cal
    292
    DSTECK,
    q.1.
    does changing the KPA and RPM axis values in VVE carry over to the coef tables
    normally changing the axis in 2BAR OS upgrade
    NotoriouSS TAD
    Mar 2008
    St. Louis, MO
    4,860
    It changes what you can actually view and edit. Just because you stop the display at 105kPa doesn't mean it's going to stop calculating beyond that.
    Mar 2006
    sunny So Cal
    292
    DESTECK hows this look
    New file,
    Massive VVE editing as a new starting point
    10-210KPA and 500-7000RPM default scales
    If this tune produces cly air and VE issues it is safe to say another issue is happening.....right?
    NotoriouSS TAD
