So I have a new Nextbook with windows 10. When I log my GTO it looks like its working but when we look at the log nothing is showing up ? Any ideas. Also is my interface ok with usb 3.0 or should I use the USB 2.0 port. Thanks again
What do you mean "it looks like it's working"? What looks like what?
The histogram is not right
needs to reference map not cylinder airmass
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
lots of stuff is showing up, lol. Do you have an "old" computer that you set everything up on? Copy your Documents/HPTUners/Settings/VCM Scanner.cfg file to the same spot on your new computer that will bring in any custom MATHS that you setup, if any. This is not in the Scanner folder, in the SETTINGS colder. Copy from SETTINGS folder to SETTINGS folder.
Then you have to make sure all your other stuff is in the channels, and all of the things match.
2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
ZL1 Wheels/Tires
