PWM Desired ECT Troubles
Running a 5.7 hemi PCM powering a v8 with the original 3.8 V6 Wrangler Electric Fan setup.
Looking to get the fan's properly working but having some troubles as it won't let me adjust the ambient air temp fields.
Might be able to make this work, but it'd be easier for diagnosis if I could just copy a stock wrangler table in here, and adjust the temps accordingly.
Let me know if you have any tips, I simply couldn't get it to adjust at all.
The good news is, I am learning.
I was able to right click, choose row axis, and edit. This allowed me to change the numbers to be similar to what I'm seeing in a regular Wrangler file. This will allow me to test and see now!
I will report back if this works properly for this scenario!
