2003 5.9 Cummins
Thanks, Removed.
2003 5.9 Cummins
Thanks, Removed.
I don't know how the ecu picks the table but my experience with logging my tunes has been that the low density table seems to be used even during transients. My truck is an early 04 so I think its the same ecu. My current tune is running both of the timing tables and both of the fuel rail pressure tables with the same numbers. I also have the table axis values the very same. This makes it super easy to copy and paste from the timing calculators.
2003 305/555 QCSB Cummins
Piston/rod/sleeve/fire ring/dual CP3/300 overs
Super Stick NV5600
S366/S480
