Results 1 to 18 of 18
Thread: VVE tuning C7Z
    Jun 2007
    Close to my Z06
    271
    VVE tuning C7Z
    How many have VVE tuned their C7Zs?? What is needed for the initial setup ??
    Mar 2010
    Texas Hill Country
    3,299
    its the same as tuning any other VE table regarding process. All the information you need is posted already. Have you read it all and now have specific questions or are you looking for a tuning guide?
    Jun 2007
    Close to my Z06
    271
    Just a quick guide
    Jun 2007
    Close to my Z06
    271
    Have you VVE tuned your car???
    13,557
    Read this if you want to do it using fuel trims.
    http://www.hptuners.com/forum/showth...621#post416621
    Search around if you have more questions, a lot of the stuff is already covered in the VCM scanner section for setting stuff up.
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by HNK View Post
    of course
    Jun 2007
    Close to my Z06
    271
    Did you use the VE vs Trims or AFR?
    Mar 2010
    Texas Hill Country
    3,299
    I use both constantly. Trims for VE can take literally forever. You must use a wideband for PE areas (heavy load and WOT). Trims are great for verification and part throttle/idle areas but trims can be wrong if you have cam and long tubes, etc throwing off the readings.
    It is best to use a wideband to tune your airflow models and then go back to closed loop and tune your closed loop system so the trims are where you want them without changing the airflow models again.
    Jun 2012
    Canada
    154
    which sensor do you pick for gen 5. the vve virtual is rpm vs map/baro (pressure ratio) tried pressure ratio but does not seem to work
    Mar 2010
    Texas Hill Country
    3,299
    you need to make a pressure ratio calculation from map and baro
    Jun 2012
    Canada
    154
    Quote Originally Posted by Higgs Boson View Post
    Higgs Boson, first off I would like to thank you for your contribution to this forum, you and others have really help. as for pressure calculation, I failed math in my younger days lol. any idea how to go about it. should I open a ticket with HP to add the calculation.
    Cheers
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by obd2 View Post
    Cheers
    Just do map/Baro... that gives you pressure ratio
    For instance a 1.4 pressure ratio is 140kpa (psi)/100 (sea level Baro)
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2010
    Texas Hill Country
    3,299
    Cheers
    its as ben says, the tool is in the upper menu called something like Math Parameters
    Jun 2012
    Canada
    154
    will try tomorrow. looks like they have some predefined calculation
    Aug 2009
    Calibrating
    3,373
    I think they do now... haven't looked in awhile... guys like Higgs and I been doing t the "custom" PID way for awhile now
    14 Gen 5 Viper
    Jun 2012
    Canada
    154
    guys care to share some of those pids? tried it via datalog i have and does not seem to work. possibility is i did not log the correct sensors . these new PCM rock. i have been logging almost everything under the sun and logging performance never seem to be effected.
    Mar 2010
    Texas Hill Country
    3,299
    just log Baro and MAP in the channels. try to use native pids with the single blue arrow in the channel/pid selection box.
    go up to Math Parameters and make sure it's either pre-setup or set up the math for one in there with the exact same channel/pids you are using in the channel list.
    then you can set up a Graph and use Pressure Ratio as the Y Axis for logging with the same values as your stock table in the VVE Editor.
    Super helpful info. Thank you for posting this info. I was confused on the Y axis and this clears it all up for me
