Originally Posted by
Higgs Boson
Tune your MAF perfectly
Tune your VVE perfectly
(these two alone may be enough to get idle right in a mild application, don't assume you need to get crazy with torque tables)
Spark and Min Spark need to be not stupid, do not try to force it to idle with a certain amount of timing. Many cars and trucks idle with 5 degrees of lead, of course you don't want -15 but 15 is also not mandatory.
Zero Pedal External Load Table needs to more like zero pedal torque, log it
Airmass and MAP Coefficients BOTH need to be adjusted properly depending on what you have done to the car, typically only with a cam swap or the like major change.
many people do not tune VVE, MAF is off and before taking care of that they chase torque model adjustments with no change.....fueling must be correct or spark will be wrong and fluctuate, etc.
when in doubt, go back to stock and start over (regarding idle).
