Page 1 of 4 1234 LastLast
Results 1 to 20 of 64
Thread: negative timing on Idle
    looking for the reason making timing on idle negative specially with camshaft upgrade
    LT4 with 2.31 making almost -5 to -10 timing on idle
    L83 with cold air intake make -15 to -10 on idle
    L83 with camshaft making -5 to -10 on idle
    is thats symptom of air leak and PCM try to correct itself or needing work on torque management also there are shearing the actual RPM less the commanded RPM (happen on D and less on N)
    WOT and cruising is perfect even not stalling but with 0 paddle
    regards
    Mar 2010
    Texas Hill Country
    3,299
    Going to have to post a tune and a log file if you want help with it.
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Quote Originally Posted by Silspark View Post
    regards
    I'd guess your predicted torque is too high so the PCM uses spark to try and pull the idle down
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    The LT4 generally pulls timing after a cold start to keep the rpm's up for a very brief time. I think it's less than thirty seconds.
    The base idle does not pull timing.
    Help us, help you! Post a tune and log for definitive assistance.
    Jun 2006
    536
    Quote Originally Posted by Speedforhire View Post
    The reason the control retards the timing at cold start is to raise exhaust gas temps to light off the cats. This is also done in conjunction with cam phasing. This is why these motors have a loud exhaust tone until it decays off.
    Quote Originally Posted by Redline MS View Post
    .......This is why these motors have a loud exhaust tone until it decays off.......
    It would be nice to keep that loud exhaust note to. Once it falls below 800 rpm's it sounds like a sewing machine. LOL!
    Mar 2010
    Texas Hill Country
    3,299
    i disable all the cat lightoff stuff because i always remove the cats! ;-)
    u r right in cold start exhaust is louder and diving u great tone, and also sometime on Decel but Im talking about normal Temp 180+, before air leak could make negative timing but u can detecting the leak but in GenV is using different methods
    I just log the car with negative timing @idle + stock with tuned files
    Please advice
    The stock tune you posted does not appear to be stock. What are these tunes from?
    Sierra 2016 Stock
    any advice ?
    Baltimore, Md
    1,210
    I cant find cat lightoff timing tables on a 2017 SS file? Obvious to find on earlier stuff
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    regards
    did you find out what it the issue ?
    Aug 2009
    Calibrating
    3,373
    Negative timing is Bc the ECU uses Tq to control idle (much like older ECUs used airflow) when you INCREASE airflow the ECU pulls timing in an attempt to bring it back
    Quote Originally Posted by Ben Charles View Post
    Yes you are right , my tps was 13% before cam and after cam it is 18% and it is pulling timing to keep idle at commanded value. is there a way to lower throttle position ? maybe idle torque reserve ?
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Ben,
    Maybe a stupid question but since i put my supercharger on, i figured i would have to increase torque some to account for the added load to turn at xxx rpm, or should i be increasing air? My thinking was since i already have a fairly large cam the idle flow rates should not change much.
    I had the cam tuning spot on but this is kicking my butt a little.
    One thing i know for sure is before the SC i could change my fuel trim output STFT/LTFT by changing torque settings. When i was dialing my cam in, I could get real close to +/- 2.0 or so by torque BUT my timing was still a little low. It was not until i dialed my MAF in that the rest fell into place.
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    I have had the exact same issue. Any tips on how to fix this?
    May 2003
    South FL
    1,368
    Have you tried lowering your Virtual Torque tables in the idle area?
    [email protected]
    Owner/GM Calibrator
    Aug 2009
    Calibrating
    3,373
    Bingo!!! That lowers predicted Tq and will help with idle timing since then it won?t try to fight its self with spark
