Page 23 of 23 FirstFirst ... 131920212223
Results 441 to 446 of 446
Thread: Injection Timing Assistance Requested
  1. #441
    Jul 2020
    Las Vegas ,NV
    14
    running WOT u want to be on a dyno or where u can see any gains as the more u delay the injection the less time the fuel has to start the atomization process so if u delay it enough (but not too much) u can use the delayed fuel atmo to get more timing into it sorta like a octane boost, u dont want to delay too much tho as u want all the fuel that goes in to burn up so its not hanging around for the next cycle causing more issues with self det
  2. #442
    Jun 2014
    Boulder, CO
    202
    Also, delaying EOIT too long can lead to the (poorly atomized) fuel washing oil off of the cylinder walls.
  3. #443
    Who here has measured with a scope the EOIT on the injectors vs crank sensor signal?
  4. #444
    Feb 2017
    miami
    1,799
    Quote Originally Posted by yellz06 View Post
    I don't know if this helps but they did something with Gen3 here
    https://forum.hptuners.com/showthrea...l=1#post559828
    I took it one step further and predicted some positions for later injection and valve events etc... but its just a guess work
    https://forum.hptuners.com/showthrea...l=1#post683573
  5. #445
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    135
    Injection timing, I log ipw and adjust up/down the ing timing until I get the lowest ipw. It's the dumbed down version vs intricate formulas I used to use. Works like a charm and very simple with a proper excel chart to know if you did good or bad on the last adjustment. I can see the changes in relation to power on the dyno and graphs smoothing out and taking proper form.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
  6. #446
    Tuning Addict
    6,781
    Quote Originally Posted by Camaro6 View Post
    This IS the simplest and best way to do it. Also how I set injection timing I still use my own personal known good curves, but THIS IS EXACTLY the best way to do it!!!
    ~Greg Huggins~
