Page 12 of 23 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 446
Thread: Injection Timing Assistance Requested
  1. #221
    Oct 2013
    Texas
    39
    Question,
    If the normal RPM is used, does the ECM use the 4096 RPM cell in the equation for RPMs above 4096, or is normal RPM dropped out of the equation above 4096 and the ECM is left with just, boundary - ECT - make up?
  2. #222
    Oct 2014
    13
    try to inject as the EVC is happening so it also gets good vaporizing going on, leaving it so it only has 52 deg before the IVC is too late if u stab the throttle it may not have enough time to get the first crack of fuel in, i have my idle injection ending around PPV or just before depends on your PW, if u crack the throttle it should stay nice and responsive
    I have a stock cam with tons of negative overlap so there is no chance of fuel making its way out of in open exhaust valve (also know as short circuiting) if thats why you suggest targeting SOI when EVC event happens. I am also basing my IVO and IVC numbers on 0.050" lift which is conservative.
    I think you do have a point that 527* for EOI is a little late. After looking at a piston velocity graph, and being reminded where most of the "meat" under the curve was I am going to do some trials with EOI somewhere between 450-490. Those EOI values are a little later than the PPV EOI of 433* you suggested. I am doing this in an attempt to account for the delay between piston velocity and intake air velocity (not travel time to cylinder as calculated in the excel tool).
    Let me know what you guys think.
  3. #223
    Jan 2014
    Australia
    1,984
    Quote Originally Posted by J-CUE View Post
    Question,
    what ever is in the 4096 cell is used above that, thats where its good to use the boundary instead because u have the full rpm range
  4. #224
    Jan 2014
    Australia
    1,984
    Quote Originally Posted by liquidforce917 View Post
    ok yea with a cam and no overlap just aim for the intake valve like stock but just not as advanced, it can help having it sit on the closed valve so just see what it likes, for cruise just see what your PW is like and adjust the cruise rpm areas to see if it helps, i dont think there are as big gains for stock cam but still some if u play around with it
  5. #225
    Nov 2016
    Baghdad IQ
    52
    hello i have 15 degree overlap cam ls3 camaro ss , i had lot of back fire when im hit the paddle from 800 to 2000 rpm , i add 10 degree to boundary the back fire is gone , but when the engine temp. hit 203f it start back firing from the intake when im hit the gas paddle at low rpm only ?? any help please ?
  6. #226
    Jan 2014
    Australia
    1,984
    Quote Originally Posted by steve-0 View Post
    is your ECT table all the same or still changes with temp..? if it changes with temp and u have overlap just make it all the same can even help with cold start, does it hesitate at same time..?
  7. #227
    Tuning Addict
    Jan 2015
    6,815
    Do what you want, but your going to want to retard it in the higher rpms much later than this... I did a big write up on all of this a long while back - keep it centered around ppv and don't go above 600 with a factory cam...
    ~Greg Huggins~
  8. #228
    Tuning Addict
    Jan 2015
    6,815
    When I said you wouldn't like it that retarded - I was referring to the lower rpms... It needs to transition gradually into the more retarded levels in the higher rpms...
    ~Greg Huggins~
  9. #229
    Nov 2016
    Baghdad IQ
    52
    thank you , do i need to zero the Normal RPM ? it still backfire from the intake when im hit the gas at low rpm ,
  10. #230
    Jan 2014
    Australia
    1,984
    yea if u zero the RPM then just use the boundary to do RPM cos it has much better scale, what's the spark like there maby a bit more could help the backfire if it's missing ?
  11. #231
    Nov 2016
    Baghdad IQ
    52
    if i increasing the boundary the backfire come from intake , if i decreasing it the backfire come from exhaust,
  12. #232
    Jan 2014
    Australia
    1,984
    something is going on if it's getting backfires either way, how's the fueling sounds like a lean tip in ?
  13. #233
    Nov 2016
    Baghdad IQ
    52
    i have afr gauge , fuel is ok , im running ported heads ported intake manifold , using MAF only ,
  14. #234
    Jan 2014
    Australia
    1,984
    is your VVE dialled in also it does get used for transients still ?
  15. #235
    Nov 2016
    Baghdad IQ
    52
    i disabled the LTFT , im ruining MAf only ,
  16. #236
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    What is the theory for modifying EOIT for a cold engine? It seems like the factory calibrations have it advanced when ECT is low then retard as it warms up.
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
  17. #237
    Tuning Addict
    Jan 2015
    6,815
    Quote Originally Posted by Niemer View Post
    Depends on cam and setup... A lot of overlap with a blower for example will probably want it to be all the same number or a touch advanced when colder - it won't like the traditional full advancement like the OE settings at all however whereas a less overlap cam will like it... If you really want to dial it in - use fuel trims and do multiple cold starts to dial it in for the different temps...
    ~Greg Huggins~
  18. #238
    Jul 2012
    371
    Couple things I noticed when playing with this Scott - First off the injector pulse width cells below 2400 rpms are protected even though they shouldn't be and then even though the regular chart shows the injection timing "soi" coming back around before the 720 degree mark - the black graphs don't correspond simply because the rpms on them don't go high enough? I know realistically most LS engines won't see anything above 7000 rpms, but is it possible to add a couple more black charts Please and Thank You
    I'm also attaching a demonstration sheet of a cam and blower setup running 16psi I know is working very well even though I honestly know the injection timing could be a touch more advanced by redline... This is solely pulse width information during a dyno pull which will include transients, so honestly you might want to just look above 2500 rpms for this reason...
    Would this be a fair statement?
    - Below 1536 rpms, keep SOIT after EVC to reduce fuel smell at idle
    - Above 4500 rpms, aim for EOIT-FRC right before IVC
    Anything to aim for between 1500 and 4500 for this case? Or revert back to the other notes?
  19. #239
    Tuning Addict
    Jan 2015
    6,815
    Best and most straight forward advice I can give - aim to keep ppv right in the middle of eoi and soi except for high rpms where you will keep eoi after fuel to port time is included at around 15 to 20 degrees before ivc... Especially where your running a PD blower The eoi is about 15 to 20 hp sensitive - you can loose that much with it being off that little and then more if it's off more...
    ~Greg Huggins~
  20. #240
    Jul 2012
    371
    Thanks, I've updated the DOCs tab with some more notes as well as a few definitions
