Page 18 of 23 FirstFirst ... 8141516171819202122 ... LastLast
Results 341 to 360 of 446
Thread: Injection Timing Assistance Requested
  1. #341
    Jan 2014
    Australia
    1,977
    Quote Originally Posted by jsllc View Post
    The red is there for a warning that you are getting close to the intake valve being opened from previous cycle. Because formulas have been adjusted and this one is not fixed to match it is calculating wrong somewhere past v17. There are other things now that may or may not be right. The make-up for one. I at first I added it on the end, then I was told to should push SOI back not be added, now it is being added on the end. Do we really know?
    as far as i know Boundary is the end so any adders like rpm/temp are added to before the boundary then makeup should be calculated same as the rpm/temp are so they add to before the boundary "advanced" further, nothing adds a delay to boundary its final everything calculates before it
  2. #342
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    If this is the case then formula adjustments somewhere past v17 have broken this excel file.
  3. #343
    Nov 2016
    22
    So which version is the best one to use?
  4. #344
    Tuning Addict
    Jan 2015
    6,781
    I've been using the last one - haven't seen or noticed any issues other than some header labeling here and there?
    ~Greg Huggins~
  5. #345
    Tuner in Training johnperks's Avatar
    Oct 2014
    wichita ks
    41
    trying to wrap my head around this. i dont have excel im using apache open office and struggling to understand the lines on the graph pages they are labeled as column d e and f. from my understanding i need to 0 out the rpm table, leave the ect table 110 then form my arched line in boundry correct?
    2005 gto m6
    kooks signature headers
    awespeed intake
  6. #346
    Oct 2014
    wichita ks
    41
    INJECTION TIMING ANALYSIS BY RPM
    ENGINE RPM 0 512 1024 1536 2048 2560 3072 3584 4096 4608 5120 5632 6144 6656 7168 7680 8192
    PW in Crank Degrees Total) 0.00 7.82 101.98 151.60 200.99 250.39 299.75 349.20 398.52 448.33 498.14 547.43 597.20 646.96 696.73 746.50 796.26
    0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05
    SOIT (START OF INJECTION TARGET) 350.00 342.18 248.02 182.32 117.58 52.81 708.09 643.28 578.61 528.80 478.98 429.69 379.93 330.16 280.40 230.63 180.86
    Fuel reaches Chamber 350.00 356.60 271.18 211.34 150.80 89.20 26.94 684.11 621.06 572.59 523.92 475.62 426.70 377.68 328.57 279.39 230.15
    EIOT (END OF INJECTION TARGET) 380.00 380.00 380.00 363.92 348.56 333.20 317.84 302.48 287.13 287.13 287.13 287.13 287.13 287.13 287.13 287.13 287.13
    Fuel reaches Chamber 380.00 394.42 403.16 392.94 381.78 369.59 356.69 343.31 329.57 330.92 332.07 333.05 333.90 334.65 335.30 335.89 336.41
    Intake Valve Open @ .006 (BTCD) -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50 -12.50
    Intake Valve Close @ .006 (ABDC) 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50 39.50
    Exhaust Valve Open @ .006 (BBDC) 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50 44.50
    Exhaust Valve Close @ .006 (ATDC) -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50 -7.50
    IVO Standardized 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50 372.50
    Intake Valve Peak @ .006 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00 476.00
    IVC Standardized 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50 579.50
    EVO Standardized 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50 135.50
    Exhaust Valve Peak @ .006 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00 244.00
    EVC Standardized 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50 352.50
    PPV Standardized 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00 433.00
    0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050 0.050
    Gross Intake Valve Lift (inches) 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000
    Gross Exhaust Valve Lift (inches) 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000 525.000
    SOIT-FRC: Degrees after EVC = -2.50 4.10 -81.32 -141.16 -201.70 -263.30 -325.56 331.61 268.56 220.09 171.42 123.12 74.20 25.18 -23.93 -73.11 -122.35
    SOIT-FRC: Degrees after IVO = -22.50 -15.90 -101.32 -161.16 -221.70 -283.30 -345.56 311.61 248.56 200.09 151.42 103.12 54.20 5.18 -43.93 -93.11 -142.35
    SOIT-FRC: Degrees before PPV = 83.00 76.40 161.82 221.66 282.20 343.80 406.06 -251.11 -188.06 -139.59 -90.92 -42.62 6.30 55.32 104.43 153.61 202.85
    EOIT-FRC: Degrees before IVC = 199.50 185.08 176.34 186.56 197.72 209.91 222.81 236.19 249.93 248.58 247.43 246.45 245.60 244.85 244.20 243.61 243.09
    Im getting some strange numbers in my fuel reaches chamber in the 3k to 4k range. did i input something incorrectly?
    2005 gto m6
    awespeed intake
  7. #347
    Jan 2014
    Australia
    1,977
    Quote Originally Posted by johnperks View Post
    zero out rpm, then lower ECT until u stop the fuel out exhaust, then u know where u are at and can increase boundary from 520 to where ever it likes to be as rpm rise, the info in the spreadsheet works well for setting it up
  8. #348
    Jun 2011
    Montreal, Canada
    758
    I had same issue trying to use the spreadsheet in anything but excel. Its just too confusing. Once I used excel its easy because all the labels are there.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  9. #349
    Aug 2014
    Central, LA
    737
    It worked just fine in libre office (stable track) for me. Definitely doesn't turn out well in google sheets though
  10. #350
    Oct 2014
    wichita ks
    41
    My pw at wot is 16.2ms this wraps the soit around the graph. do i just continue to raise the boundry then? i downloaded excel today and so much easier knowing what the labels are.
    2005 gto m6
    awespeed intake
  11. #351
    Oct 2014
    wichita ks
    41
    I've played with sheet some and think I'm on track. Would anyone know if I'm finally grasping correctly?
    2005 gto m6
    awespeed intake
  12. #352
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    Expect VE map to be way off after making these changes and would appreciate any comments about this being setup right. Still need to re-verify PW vs RPM.
    Basically centered at PPV until EOIT reaches IVC, then worked backwards.
    This looks great on paper but has anyone verified the injectors really follow this spreadsheet?
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
  13. #353
    Jan 2014
    Australia
    1,977
    thats very delayed 670, furthest i have been is 600-610 and my other tables are same as yours, u could try it but keep an eye on the wideband encase its too far and it may even need some more timing up top to suit, GHuggins im sure will have a good idea of what it will be like tho
  14. #354
    Jul 2016
    Flanders nj
    283
    Easy enough to end it earlier...just limited it to the recommended 15* before IVC as per the doc page. Definitely needs some re-tweeking on cold starts and idle airflows now. I was spraying way too early before and the intakes must have been sucking puddles from the runners. Oddly enough it was idling and running great though.. I save the old tune and will spend some time seeing where this goes.
  15. #355
    Jan 2014
    Australia
    1,977
    it is affected but a few things as i found like how free your exhaust is ect where once i got the twin 3" i could delay it a little more up top (like a good 60+ deg) so maby it wasnt clearing out of the chamber enough before
  16. #356
    Tuning Addict
    Jan 2015
    6,781
    Quote Originally Posted by NJ_Phil View Post
    2000rpms to 5600rpms - way too retarded - you want to focus more on the intake valve through there and then shift the dotted red line over to about where the solid red line is - you may even be able to split that in two and be good, but definitely fix the mid rpm areas...
    ~Greg Huggins~
  17. #357
    Jul 2016
    Flanders nj
    283
    Most stuff I've read says when possible avoid SOIT while the exhaust is still open (overlap period). Advancing as suggested would push SOIT into overlap ????
    EDIT: BTW Graphs don't reflect changes for exhaust valve duration and LSA on v21
  18. #358
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    So I actually just started looking deeper into this tool and believe there is a double dip of Make Up Pulse (MUP). I was using my abacus related tool set for a customer and decided I would really give this awesome tool a run. I kept coming up 30 degrees different. I personally didn't include the MUP in my dinosaur so I added it for grins. When I was done, I kept coming up 30 degrees different on the SOIT...As I started looking I saw that the EOIT and SOIT values in the Table tab both include the MUP (Input!D21). Believe it should only be in one....or none :-)
    Before I didn't even include the MUP. As I am not really keen on when and how often the PCM initiates this extra pulse, what impact do you think it would have. I'm leaning towards if its duty cycle for interaction is very low....then maybe it doesn't need to be included. It especially impacts trying to place the idle injection event in and around the PPV.
    Ed M
    PS -- Will, I'm working on it .......:-)
    [email protected]
  19. #359
    Tuning Addict
    Jan 2015
    6,781
    Pretty sure that it's only used during idle and cruise. Chris said that he couldn't confirm for sure, but I've had pretty decent luck with the tool so far.
    ~Greg Huggins~
  20. #360
    I read the first post and thought wow he pulled some nice times with those adjustments then the next post went in another direction...My brain hurts.
    2008 Corvette
    UPP Twin turbo T4 67mm BB billet wheel kit
    427 LME Billet Setup
    Fore Innovations Triple 465 L4 Setup
    FIC 2150 injectors
    RPM TH400/9 inch
    Pro Torque Bolt Together Converter
    MaxxECU Stand Alone
