~Greg Huggins~
I've read about this too. Basically, the theory is peak combustion occurs later. In this instance, the goal is not really pushing the piston, but pushing the turbo wheel. Delayed injection timing basically creating a huge push in the exhaust port and the primary tube of the manifold or header...
Yep... I think you're right. I'm still playing with the spreadsheet. I'm going to try to get it around 10 IVO plus 10-20 degrees. Incoming fuel should hit a hot exhaust valve and vaporize a little. SOIT and EOIT should happen before PPV at lower rpms and make good power as a result. That's my thinking anyway
The cross hairs are a carry over from schpenxel's stuff. I kept them, not knowing exactly how he is using them. I mentioned it in one of the posts. Maybe he'll respond when he gets a chance.
Thanks for the input on the curve. I ran the truck as it was last weekend - didn't mess with the injection timing. I doubt it'll have a huge (Trump says yooge) impact since I'm running a turbo build without an actual turbo.
Speaking of turbo... anybody care to recommend, or sell me, a good turbo? I'm leaning towards the Precision Turbo 88mm Pro Mod ceramic ball bearing setup with a 1.40 A/R. I think the new Garrett GT5533 Gen 2 88mm is a good piece too. Thoughts? Prices???
The cam in my engine is a BTR Stage IV Turbo cam. It's not a stock grind.
The crosshairs are a carry-over from schpenxel's stuff. I'd like more information on how he is using the crosshairs... I'm trying to "leverage" (a word used in the software industry to say copied without actually saying copied) the work he's already done to create something that's a little more informative.
Glad you like the spreadsheet. I like visuals too.
If it's copied from carsons - the cross hairs should open and close representing both soi and eoi... They don't actually cross anything specific - it's the beginning and ends that you have to focus on...
I need to relook at his, but I think that's how it works... This would be fine, but nicer if you could have beginning and ending lines
~Greg Huggins~
Yeah the cross mark things were supposed to represent the injection time.. so left side would be SOI and right edge would be EOI. Or maybe I'm misunderstanding but that's what I think scott is asking about? I thought it made a nice easy visual for "where" fuel was getting injected in the grand scheme of things
And I couldn't find another easier way to do show that in the graph so that was my work around
Ok... thought so. That's how I understood it. I think the values in the graph are referencing constants. I'm going to re-check the formulas to make sure they are accurate. Seems like the goal is to make sure SOIT and EOIT reflect the whole "injection event" from start to finish. Might have some free time tomorrow.
Still open to turbo suggestions...
Values in the series are referencing SOIT and EOIT... which is great. However, the second set of values point to .200 and .500 - which are constants. IN the graph, it is shown as lift. I need to figure out a way to show where injection takes place relative to lift. Not sure how to do that right now
Huggie (if I may be so bold to call you Huggie)... take a look. I'm showing vertical lines for SOIT and EOIT that intersect the lift curves all in relation to the peak piston velocity. Let me know what you think.
No please don't Also really liking the spreadsheet - not sure if it matters - but can we get all 720 degrees of crank rotation with BDC and TDC designations below?
I'm actually thinking about partially using this to help design cams now You've put a lot into the illustration...
~Greg Huggins~
I'll have to look at it in more detail, but something looks off with the cam opening and closing points in relation to crank degrees?
~Greg Huggins~
~Greg Huggins~
Like this?
Numbers for my cam are at .050 because I could locate the .004 or .006 values...
~Greg Huggins~
Yeah that's getting to be a bit too much going on IMO... I like the last file posted though.. it's def getting better with you guys working on it!
I think once the format is all setup we might could do some drop down boxes or some other way of setting what RPM each chart is for.. I think that would work better than having 20 of them for different points. Or maybe just one for every 1K RPM's or something like that once over 2K? I dunno, just thinking about it
