Page 5 of 23 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 446
Thread: Injection Timing Assistance Requested
  1. #81
    Tuning Addict
    Jan 2015
    6,816
    I think once the format is all setup we might could do some drop down boxes or some other way of setting what RPM each chart is for.. I think that would work better than having 20 of them for different points. Or maybe just one for every 1K RPM's or something like that once over 2K? I dunno, just thinking about it
    Or just have one graphic with changeable rpm inputs that would then change the graphic to match that rpms designated numbers?
    ~Greg Huggins~
  2. #82
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Yeah that would work too I think.. maybe just have 2 or 3 graphs and you can set the RPM for each of them to use
  3. #83
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    Maybe add a sine wave for crank angle (TDC thru BDC) using a dashed line, 50% opacity ???
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
  4. #84
    Tuning Addict
    Jan 2015
    6,816
    Made a very minor change to the ect input - probably screwed something up, but I just made it to where you can input a number in one cell and it changes the rest... Tried playing with the visual a little - really screwed that up So I leave that to the pro...
    ~Greg Huggins~
  5. #85
    Tuning Addict
    Jan 2015
    6,816
    OK injection timing at 6650 - can we do the axis like this - this would incorporate everything I think with crank rotation and piston position...
    ~Greg Huggins~
  6. #86
    Tuning Addict
    Jan 2015
    6,816
    I know I'm nit picking crap now, but what about this?
    I can always personalize it later - just thought the darker colors might stand out better with all of the white? Then line colors can be made whatever you like the best...
    ~Greg Huggins~
  7. #87
    Potential Tuner Brian Rowland's Avatar
    Dec 2015
    Memphis Tn.
    9
    Awesome looking work men. Hope to become smart enough to use those spread sheets one day !!
    C6 Grand Sport A6
    LS3, YSI @18# , E85, NOS, Circle D 3800, RPM Stage IV w/ 3.15, Penske Coilovers, 15" rear conversion.
    1008 RWHP 855 RWTQ
  8. #88
    Aug 2014
    Central, LA
    737
    This new and improved spreadsheet looks really great. Glad I didn't do my eoit yet
  9. #89
    Jan 2014
    Australia
    1,984
    can the makeup duration be added in as a constant so its in all calculations..?
  10. #90
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I'm liking it!
    Ok, stupid question, what is PPV? I'm having a blond moment
  11. #91
    Tuning Addict
    Jan 2015
    6,816
    Peak Piston Velocity - that's ok - if you look a couple post back - I couldn't remember how to figure the boundary
    Now for Sottt28 to possibly get it finished, because I only know how to screw things up in excel and he's done some pretty dang good work here
    ~Greg Huggins~
  12. #92
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Ah ok, good to know
    Who did the black looking chart in the pictures? I like how that looks quite a bit better.. at least it isn't the regular vanilla looking Excel charts
  13. #93
    Tuning Addict
    Jan 2015
    6,816
    I did, but I did my usual "caveman" approach and started clicking on anything and everything until menus popped up I like it that way too - stands out better and is more "visually" present "I think"...
    ~Greg Huggins~
  14. #94
    Apr 2007
    1,104
    if i could weld and work over excel. id be dangerous lol
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
  15. #95
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Wish I could weld too
  16. #96
    Jan 2014
    Australia
    1,984
    definitely gives a good visual of where things are at been playing around on it redoing my adjustments, the black would be good i have the hpt scanner like that its easy to look it
  17. #97
    Tuning Addict
    Jan 2015
    6,816
    How does anyone using excel not pull their hair out
    I know Scottt28 could not only probably do this better, but probably a whole lot quicker than I...
    Anyway - just took Scott's and added the black visuals in and changed the base axis to a crank degrees representation... If the links are broken - sorry, but it's my fault...
    I think he'll have something a whole lot better for us though... Just a feeling I got
    ~Greg Huggins~
  18. #98
    Sep 2016
    39
    I've been lurking on this thread, making my own version of this to fit my build for when it's time to tune. As for graph views, here's what I've come up with. I think knowing the piston distance (and therefore velocity) is a good piece of information on this (think is the key word) so I added it in.
    maybe this kind of graph Would be easier for visualization. I would need to clean up the inputs before I'll upload the .xlsx but if anyone wants it just let me know.
  19. #99
    Tuning Addict
    Jan 2015
    6,816
    Don't know - I guess because I'm so used to the degree wheel, that the piston relationship in degrees below the cam points works better for me? I do like that you have all of the ppv's on yours - but this is only really needed for cam profiling... Just don't like the piston chart being on the cam chart? But that's me... You definitely know how to use excel better than I do
    Was playing with yours Scottt28 - Is it possible to have soi come back on to the end of the chart in negative degrees relationship or is that going to be impossible? I just noticed that if the pw's are really high or you timing is advanced at all enough in the higher rpms to go to a negative relationship on the graph - it extends out the lefthand side of it and shows negative numbers... Not 100% necessary, but was just wondering...
    ~Greg Huggins~
  20. #100
    Tuning Addict
    Jan 2015
    6,816
    Scottt28 - I also think I possibly broke your cam calculator? I input numbers and hit calculate, but it wasn't changing anything that I could tell I assume it's supposed to change the numbers up top? Will it also give you new numbers listed below it or is that just an example? Anyway - seems like I just screwed it up...
    ~Greg Huggins~
