Hello guys, firstly, I have a 1996 GMC K1500 with a lot of upgrades which includes HT383e, swapped stock ECM to 0411 (out of a 2002 GM express van), upgraded transmission, 6" lift, steering, suspension, interior....blah, blah, blah,...everything from the brakes up through steering wheel is all brand new (yeah, I spent sum bucks/and a year of my time),.....hell, the frames even been grinded down and repainted throughout.
I'm in the final throws of passion,...truck runs like a dog "sneakily" shot in the ass with a Daisy one-pump bbgun (it's quick). I just bought HPTuners and going through it. Just dialed my dizzy into final alignment within +/-2 degrees (HPTuners made that easy), which cleared my P1345 DTC.
My problem is that CASE relearn (crankshaft sensor relearn) throwing the P1336 code. I did it exactly like the "help" section and,...read just about every chat on here concerning this relearn procedure.
Both brakes pressed, start engine, then when I get to the step "click relearn" - I do - then rev engine up to over 5K (till my rev limiter cuts fuel at 5,200 - high torque truck - not high RPM/horsepower driven). Step off pedal and comes back to an idle - shut truck off for at least 15 seconds. The whole time,...nothing happens on the HPTuners screen. Is there supposed to be a screen that says "your good, or, your done" or something/anything?
I've done the crank relearn procedure at least 8 times and every time it's the exact same thing. Figured I better check here before I break something. And, code P1336 never goes away (I check it after each procedure).
