Results 1 to 5 of 5
Thread: 2014 1LE Camaro * Can I swap Cals to get 2bar OS
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    2014 1LE Turbo Camaro
    HPT does not offer the 2bar OS for this OEM 1LE Cal
    Can I swap a 2SS Cal to get 2bar OS? on this 1LE?
    Worried about BCM, Key issues or any other unforeseen side effects...
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    13,564
    There is no need for a 2 bar OS, just extend the VVE table to support a 2 bar map.
    I don't know what would happen if you tried to write an older tune into yours, something could go wrong and brick it.
    Mar 2006
    sunny So Cal
    292
    Boost ref Fuel and Spark with 2 bar OS
    I do not want to snap to full boost enrich and spark ret while building boost
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    Swapped in a 21015 2ss Cal in place of the 2014 1LE cal
    worked great, zero bad side effects
    LS3 Turbo responded great to the 2bar 02 and tuning
    NotoriouSS TAD
    Dec 2008
    on the Dyno
    1,825
    Did you write entire the newer OS with HPT or did you dealer flash it with a 2015 VIN?
    Located in Central Kentucky
    ShorTuning
