Long list. Very long. Great features. You'll love it.
1. Separate the default (last used) path from Editor and Scanner.
If the last file I opened in Editor is in my "tunes" folder, don't make that the default folder in Scanner, where the file I want could be a previous log. Each program should remember it's last path independent of each other.
2. Make it more obvious which files I'm comparing in Editor.
If comparing file after file in Editor, how do I know which files I'm comparing? You show the entire path in the title, with preference given to the path (left side of the full path), instead of the file name itself. So if I have a long path to Logs and Tunes AND I have folders inside of that, I see the full path and file name of the first file in Editor's title, but only the path to the second file on my tablet.
You could right justify the names in the title, giving half the width to each, so the path is truncated. Or better yet, give me an "info" icon in the comparison log that tells me the file names, maybe even the notes from "tune details", if present. Maybe both?
3. Make Suite more touch screen friendly.
I use a 10" 2-in-1 table for tuning with a mount to hold the tablet (keyboard removed) for logging. Icons are a bit small for use with a touch screen, even tho I use larger setting (175%) for scaling. Please give me the option of toggling 50% larger icons.
4. I'd like a dark theme for Scanner.
I often log at night with my tablet dead center mounted to my dash and the white background can be too bright at night. Can I have the option of inverted colors (black background replaces white) for night use? Or let me use the dark theme built into Windows 10. Either way would be preferred to stock.
5. Add filters to the comparison log (team edition).
Several of us with different year Volts tune as a team effort, but there are differences between the years that we always have to leave intact. Being able to create a filter that hides or grays out certain sections would make that a LOT easier. Then I could load a filter by name (1st Gen Volt) and it would hide tables that I chose by a right-click menu. Ideally this would be a white-list or black list.
Let's make HP Tuners great again.
