hey I just got done swapping a 2005 Silverado v6 to a 2002 5.3. We used a 2004 dbw harness that I had originally and used his v6 pcm. The v6 pcm are all dbc so I added the tps and iac to the 04 harness to keep his dbc. I thin looked up a matching 2005 express 5.3 van tune and segment swapped the engine side with a "write entire". After doing all this I went to start the truck and all is does is turn over and crank thin stops. It does this as long as u try it. Never had one do this. (by the way battery and all fuses are good). We checked over everything even park/neutral safety switch and couldn't find any issues with it. So we figured something has to be up with the tune or pcm. I looked over everything and cant come up with nothing. I turned off all cods, vats etc. for the swap. Still no fire.
So, my buddy went and borrowed a 2004 pcm from a friend to try. We installed pcm and truck started up and ran until vats kicked in. We were surprised it actually started. So as to my question what could be the cause of this? Is the other v6 pcm bricked and unusable? or should I try another different segement swap into it? thanks in advance.
