Thread: Startup surge 07 Charger
    Tuner WongBob's Avatar
    Aug 2009
    Minden, LA
    65
    Been trying to get a startup issue lined out on an 07 Charger 5.7 with a comp 268 cam. When I start the car hot or cold it will surge 3-4 times and level off. Once it levels off it is good in any other situation. Part throttle and WOT is done, but I would like to get rid of the startup surge. I have tried adjusting the throttle body airflow, large and small range, and startup airflow. Nothing seems to help other than raising the large/small ranges at 31lb/hr to match at 72lb/hr. I know that isnt correct but it helps. I tried lowering throttle body airflow, but that makes the surging worse. Any tips would be greatly appreciated.
    07 Charger RT OL Cranking Test.hpt
    TBSS Cam Only Record Holder 1.467 60', 11.568 @ 116.86
    Second Fastest Naturally Aspirated TBSS 1.484 60', 11.144 @ 119.46
    Have you tried playing with the idle derivate and proportional tables on P/N ?
    09 Pontiac G8GT LSA conversion & cammed (HP Tuned)
    07 Trailblazer SS Cammed & Nitrous Fed (HP Tuned)
    Aug 2009
    Minden, LA
    65
    Yea thats how I got rid of all the other surging.
    Feb 2016
    431
    If reducing TB airflow made it worse, try icreasing TB airflow under 1v.
    This will slow and reduce TB movements at idle and may help calm it down.
