I recently swapped a crate LS3 in to my '99 Camaro SS. I'm using the OEM LS1 PCM. See the engine link for details on the engine.
I'm having difficulty getting the engine to idle smoothly, and the bigger problem is idle under load. The engine stalls when turning off throttle as in when coasting because of the increased load of the power steering.
In the attached scan from 30-39s and from 1:20 - 1:29 I was turning the steering wheel back and forth. I'm not able to safely drive the car to finish up the tune and break in the engine.
Can someone give me a hand?
