Results 1 to 17 of 17
Thread: Clutch Protection
    Clutch Protection
    Hi,
    How do I go about disabling the clutch protection on coyote cars? I was told to 0 out the enable energy table under trans>tq management. Although, the way I read the decription of the enable energy, I think I should raise this table to the max to disable the clutch protection feature.
    Any input is appreciated, thank you!
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Set the launch OSS rpm and Max time to 0
    Thank you, I'll give it a try!
    Tuner in Training WildHorse's Avatar
    May 2020
    40
    Quote Originally Posted by Blue-Z View Post
    Old thread, sorry for the bump but did it work ? I've been having problems with clutch protection kicking in. You can clearly see it here when I launch
    https://www.youtube.com/watch?v=AJTKrRlkrc0
    Feb 2012
    TEXAS
    637
    set clutch protection launch to (0) disable oss
    Clutch protection max time (0)
    Clutch Protection torque limit set entire table to 1500 ( clucth protection torque limit Vs Clutch energy Vs Clutch power)
    May 2020
    40
    Quote Originally Posted by mstang_man View Post
    Hello, thanks for the info ! When I changed the tables (CE vs CP) to 1500 it said 'parameter out of range' and automatically entered a value of 1,141.
    Feb 2012
    TEXAS
    637
    [QUOTE=WildHorse;682343]Hello, thanks for the info ! When I changed the tables (CE vs CP) to 1500 it said 'parameter out of range' and automatically entered a value of 1,141.[/QUOTE
    check the box when the message comes up and click yes.
    May 2020
    40
    Thanks again. So this looks right ?
    May 2020
    40
    Bump.
    Jun 2020
    794
    You might also max out the enable energy. Otherwise I think it looks good. I never tried it though, and in most cases the thing that seems intuitive doesn’t work the way you think it should.
    May 2020
    40
    Quote Originally Posted by engineermike View Post
    To 1^6 ?
    Jun 2020
    794
    1^6=1 so I don’t think that would help. I don’t know what the max value is. Usually vcmeditor tells you that.
    May 2020
    40
    Sorry 1,000,000. That's the max with the editor.
    Feb 2012
    TEXAS
    637
    Quote Originally Posted by WildHorse View Post
    should not have to max out energy. the original setting i post should be all that's needed.
    May 2020
    40
    Well I asked about the torque limit (circled, far left of pic I posted) & everything else was correct ?
    Feb 2012
    TEXAS
    637
    with torque limit you could try setting to 2048. I usually have it set to 750 because thats considered the max for an NA coyote.
    May 2020
    40
    Thanks.
