As far as the ecm side of the traction control settings goes - on Camaro's or Vette's running different sized rear and front such as drag race setups - I increase the torque settings for those still wanting to run traction control to keep traction from activating the brakes on and off while cruising down the road - it'll actually feel like a misfire going down the road when this is taking place... So by adding 100 or 160 to the tq input it helps keep traction from kicking in by allowing "some" seen wheel spin... Don't know the specifics and thinking about it now - it doesn't make a whole lot of sense, but that's what it seems like it's doing because if you have actual tire spin - it does still kick in...
