Results 1 to 4 of 4
Thread: 2015 silverado power enrich
    Feb 2007
    SC
    61
    Working on 2015 silverado not going into PE. The commanded AFR stays at 14.11. Occasionally PE will engage above 4000 RPMs. Anyone had an issue like this?
    Sep 2015
    22
    Peak torque table needs to reflect actual engine torque.
    Nov 2009
    All Around
    3,149
    this is not your normal older e38/e67 pcms
    everything is torque based/calculated
    Tuning Addict
    Jan 2015
    6,775
    Put enable torque percentage back up around 30 to 50 or so too - right now unless I'm mistaken you have it setup to delay per other settings in the tune...
    ~Greg Huggins~
