Results 1 to 10 of 10
Thread: Injector and fuel pump duty cycle?
    Apr 2005
    Sugar Land, TX
    1,198
    I've logged what I thought to be the correct channels for injector and fuel pump duty cycle. 4.8-4.9 ms converts to about 25% inj. dc. I would assume that would be times two for both banks? If so the factory injectors are plenty big for a 10.6 @ 130 mph pass.
    Not sure I believe fuel pump duty cycle at only about 15%. Only channel I could find for my 2017 C7 Z06 that has to do with fp dc.
    Mar 2010
    Texas Hill Country
    3,299
    direct injection engines only spray between EVC and spark, not from IVC to IVO like port.
    this is why DI is great under 700 rwhp and done after that (until you add a fuel lobe and/or meth).
    you are reading the HPFP DC, not the in tank pump.
    Apr 2005
    Sugar Land, TX
    1,198
    Thanks Higgs. DI is new to me for sure. Looks like there are no channels available to read what I would like to see. My 2017 is almost stock anyway so for now fuel isn't a problem.
    Monitor high and low side fuel pressures. When you are pushing the limits of the fuel system you will see it there.
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by Kyle_Customizer View Post
    No channels for those available at least for my 2017.
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by 8850 View Post
    its called Rail Pressure and Fuel Pressure
    I watch pulse width for DI cars. Once you start going over 5ms you are technically out of time to inject. You can inject a little earlier or you can command higher fuel pressure but once you really get into the 725 range on C7Z parts you will need meth as you won't be able to keep PW down.
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by Higgs Boson View Post
    Thanks Higgs! I'll log that next time out and see where I am. It's almost stock but would like to check before adding more mods.
    Mar 2010
    Texas Hill Country
    3,299
    well according to the screen shot you are at 4.8 :-)
    Apr 2005
    Sugar Land, TX
    1,198
    Quite a fuel rail pressure I have at over 3K psi. Not sure I believe the numbers in my log.
    I did lose traction. Car won't hold traction at 60 mph with my factory radials even on concrete.
    Mar 2010
    Texas Hill Country
    3,299
    Set your rail pressure units to mpa so it's easier to compare to your tune commanded value.
