have a 2007 f250 6.0l 2wd .. truck has newer 20" wheels there 275/65R20 trying to get my speedometer correct but no matter what I set the vss revs per mile to .. it does not change anything .. what am I missing?
Nobody seems to know. Try calibrating for 38's...lol. I haven't figured it out either. Mine stays 5 mph slows no matter what... I am guessing that HP doesn't have all the PID's.
2023 Ford Edge ST
2020 Ford F150 King Ranch 5.0
33 inch tire. 630 revolutions per mile. Don't know if this info will help but that's how it seems the pcm on these is setup is revolutions per mile x whatever your rear gear is.
My 20"s show 655 revs per mile and 3.73 gear ration in HP Tuners. Don't know if this helps you or not.
I believe the ABS module controls the speedometer on these, which we currently do not support.
Eric Brooks
HP Tuners, LLC
Update one this issue?
2023 Ford Edge ST
Just wondering, did you recalculate your N/V base and disable "use VID's", I did on my 04 and it worked, the tire revs do nothing.
based on the info you have gave previously i calculated your N/V base at 31.4033. hope this helps
