Results 1 to 6 of 6
Thread: 2007 Crown Vic Manual Swap, engine shutdown problem
    Tuner Turbo_Mike's Avatar
    Feb 2016
    Putnam, CT
    130
    2007 Crown vic P71, swapped manual trans into it. PRNDL switch is plugged in and in Neutral.
    It revs to 3500 and then dies. Cooling fan stays on. Tried to fix with HP---
    Factory settings: Auto trans enabled, 4x4 enabled, trans strategy 6
    What I've tried:
    Auto trans enabled, trans strategy 0 and 1 - I get 4500 rpm limit, even with all limiters set at 7k, stays running, cooling fan on.
    Auto trans disabled, trans strategy 0 and 1 - Get 3500 shutdown AND no speedometer. Cooling fan works normal.
    Along with this, I've disabled just about everything in the PCM that there is to disable, codes, DBW logic, torque management.
    I'm wondering if the auto trans disabled isnt disabling everything. I get a PCM RPM error code as well. I think the lack of trans rpm sensors is causing the shutdown, but I cant seem to do anything to disable the logic. Anyone run into this? Is this within the capability of HP to fix? Yes the car ran fine as an auto.
    -Mike
    2003 305/555 QCSB Cummins
    Piston/rod/sleeve/fire ring/dual CP3/300 overs
    Super Stick NV5600
    S366/S480
    Apr 2015
    45
    Mike, I'm currently having the exact same issues with a 07 crown Vic manual swap.
    Have you made any headway?
    Thanks,
    Tyler
    Advanced Tuner yonson's Avatar
    Nov 2007
    MiSSiSSiPPi
    234
    Did you try raising the neutral rev limiter?
    Oct 2007
    Crawfordville, FL
    2,409
    You cannot shut down the auto logic. Unlike the EEC-V which you could. Best thing to do here is to flash a manual operating system in from a Mustang.
    Eric Brooks
    HP Tuners, LLC
    Jun 2018
    ontario canada
    26
    Eric. I?ve been trying to work with this same issue on my 05 vic pcm
    This morning I tried licensing an 05 mustang tune on my pcm but it just gave me cranking with no start.
    Did I do the strategy swap correctly?
    I licensed and wrote the tune
    Read it back off the pcm and re wrote.
    It didn?t prompt me to license it for the second re write though..
    Jul 2020
    10
    I have a 2010 vic im doing the swap soon have you tried this..
    https://www.youtube.com/watch?v=2CpSjOIVR6o
