Results 1 to 16 of 16
Thread: Hellcat Fellas! U1424 and P1DD2, what do we know
    Mar 2017
    4
    What do we know about larger throttle body flow and torque calculations at or near idle? Working with a monster throttle body on a big blower Hellcat, only issue left with the car is if left idling it throws these two codes. I understand it is flowing more air than it is looking for, but I haven't been successful in harnessing that in yet. Anybody else out there dealt with this yet? When logging idle you can see how far off actual torque vs desired is. Log attached, any thoughts or input appreciated!
    Jul 2015
    878
    Whipple 4.5 and their big oval T/B?
    Mar 2017
    4
    Yes sir. Messed with one?
    Mar 2017
    4
    Looking like HP doesn't have the table to make this work. Grrr
    Feb 2015
    Las Vegas, NV
    36
    Post up your tune file - I dont have a cat file infront of me - I thought there was a value for this - its assembled from 2 different idle tables.
    Doc
    Doc's Performance & Dyno Tuning - Las Vegas NV . Tuning any and all cars!
    Jul 2015
    878
    Quote Originally Posted by DRTurbo View Post
    Are you talking about the small and large TB airflow tables?
    Jul 2015
    878
    Quote Originally Posted by CravenPerf View Post
    Make sure you don't have any vacuum leaks. I had some "issues" with ours. Also you need to log total air flow. That's the T/B airflow.
    Mar 2017
    4
    No leaks, I'll let you know if our current solution doesn't fix it, found a fix in another software, now we will see if we can make the HP side work. If it works I'll post it up.
    Jul 2015
    878
    Sounds good. If you know what tables you need see if HPT will add them.
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    431
    Make sure you using the latest VCM Suite 3.4 or VCM Suite 3.5 beta. We are constantly improving the software, fixing bugs, adding parameters, etc. Especially in VCM Suite 3.5 beta, new stuff gets added almost daily. Your issue may have been solved in a newer version of the software. If you need the beta, just email support. Make sure to include your MPVI Serial Number.
    After you download latest, be sure to check over your tune again and make sure that everything is set the way you need it to. I know we corrected a bug or 2 that were affecting 15+ Hellcats/SRTs recently in beta.
    On the dyno
    232
    Just finished one up. Was having a lot of issues with map sensor rationality checks, torque calculation and getting the etc light @ idle in neutral with p2110. I had to go through and find all of the map checks, the pwm threshold @ idle and the engine torque calculation table and have them all added so that i could get it right. Car drives perfect now. No limp mode driveability is perfect.
    On the dyno
    232
    Ask Mark to add the stuff i requested and you should be able to dial it in.
    Btw hpt still hasn't added the parametet to open the throttle fully for whatever reason. I did find it though
    Feb 2015
    Las Vegas, NV
    36
    I keep catching limp mode in new ways on this 2016 hellcat - it seems that everything is logically set to just not car how much airflow it sees- currently P0069
    Doc
    On the dyno
    232
    There are offsets for map baro correlation which can be opened up to remedy that. Have them added
    Jul 2019
    do you have a email address so i can send you my hellcat calibration having trouble with U1424 P012B whipple 4.5 id 1300cc
    Jan 2019
    33
    Quote Originally Posted by edgar View Post
    Try entering these parameters :
    https://photos.app.goo.gl/khrT6JCkbiJDHUxz9
    If fixed my U1424 code. I don't know how it worked, but it did.
