Page 10 of 10 FirstFirst ... 678910
Results 181 to 200 of 200
Thread: Maybe, just maybe an end to SD issues?
  1. #181
    Oct 2004
    Greensboro, NC
    67
    Tune for this month.
    03 LS-1 Vette, LGM Longtubes, BillyBoat Bullets, Halltech Stinger, Shaner ported & polished TB, LC-1 WB, Elite E2 Plate, BPP Shifter, DTE 4:10
  2. #182
    Apr 2004
    Erie, PA
    464
    Question
    I understand it better but still have more questions.
    In the table I posted below, what do the actual 0-150 numbers mean? If its g/sec, g/sec of what, fuel or air?
    Can I scan for this value in the table?
  3. #183
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    it is the airflow in g/sec (dynamic airflow)
    Sulski Performance Tuning
  4. #184
    Apr 2003
    Almost 2000 feet.
    7,876
    Disable your AIR injection as a test... (Temp to 284 F)
    Always Support Our Troops!
  5. #185
    Oct 2004
    Greensboro, NC
    67
    Quote Originally Posted by EC_Tune
    That fixed it!!!!
    You guys are the best!!!
  6. #186
    So has this been tried in CLSD , if so do the same results in stable fueling show ?? I am going to try this , as my fueling from morning to evening ( OLSD ) shows up to 8 % difference ! In the morning on the way to work VE error remains around 0,1,2 in most cells , on the way home in the evening ( 25 minute drive ) I see anything from +1 to +6 !
    So its time to stop & try to get this more stable ! I have been tuning VE in 25 minute logs , 2 a day , for over a week now n still no stability !
  7. #187
    Jan 2005
    Concord, NC
    8,093
    the car also changes from dead cold start to warm starts as well, have to remember that. So what you see in the AM may not be what it would show if the car was started warm.
  8. #188
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    this has been tried in OLSD CLSD OLMAF CLMAF and works great on all methods for me
    slightly rich on cold mornings...but youwant it to be that way anyways for a good cold startup.
    bias table is the key on 2001+ vehicles
    -Scott -
  9. #189
    OK , Made a few changes to my tune ( OLSD )! Went for the Bias of 1 across the table , Added 10% to existing VE for a start & turned off DFCO ! Logged 25 minute drive to work which resulted in averages of +1,2,3's up to 3600rpm / +3,4,7's up to 5600rpm ! Made changes to VE !
    Logged the drive home from work with the changes made ! Resulting in 1,2,3's in 2000rpm column , majority of 0 & 1's from 2400 to 5200rpm with a scarce 2,3 & 4 ! Already I can see that this runs much more stable in the fueling than before !! Will try to get some more logs & continue with the VE over the next few days !
    Thus far from todays results , a BIG Kudos to you guys for sharing this with all ! Maybe all my tunes from today onward will be using your method & hopefully bringing some consistancy for the boys running at the track !!
  10. #190
    Jan 2005
    Concord, NC
    8,093
    glad to hear it worked
  11. #191
    good ole "search" function drug up this old thread, but is directly related to my question.
    "cylinder charge temperature" Complex model....enable or disable.
    description states for FI applications and relocated IAT sensors its "helpful" to disable this function?
    My situation is a procharged LS1, with the IAT sensor relocated in the induction tubing just prior to the TB. This seems to be working great, I have tweaked the timing tables under the IAT adder section, in hopes that an Alky failure will not add timing due to not seeing the lower IAT's....so far so good.
    Now my question is should I review this whole thread and go after the Bias changes? or simply disable this function as I seem to be setup correctly to do so.
    If I disable the function, what ramifications can I expect to see?
    Thanks guys...steep up hill learning curve..but I am trying!!
    2004 GTO M6, 403, Callies, compstar, wiseco, QTP HV oil pump, QTP 2 piece timing cover, EDC custom AFR 235's, LS6 intake, P1SC-1 Procharger maxed @ 13psi, 224/232 600/600 114 EDC custom cam, JBA shortie headers (thanks California) custom boost referenced return style fuel system with surge tank, walbro 255, staged magnafuel 4303, Dual LC-1, Dual Aeroforce Interceptor gages, Nexus fP and boost gages.
  12. #192
    Jan 2005
    Concord, NC
    8,093
    what year is your car?
  13. #193
    Quote Originally Posted by WS6FirebirdTA00
    Sorry....2004 GTO
  14. #194
    Jan 2005
    Concord, NC
    8,093
    OK, I was just asking because it does not work on the pre-2001 calibrations.
  15. #195
    so should I disable?
    Or re read this thread and tweak
  16. #196
    Jan 2005
    Concord, NC
    8,093
    If it was enabled on my OS, I would tweak it. If you want the easy way out, disable it and just keep an eye on your fueling all the time and retune for weather changes.
  17. #197
    May 2008
    i live in ny, but i'm in memphis right now
    30
    what happened?
    What ever became of this discussion?
  18. #198
    Jan 2005
    Concord, NC
    8,093
    It kinda went off on a lot of tangents, what do you want to know?
    I tried to have my IAT set to constant and it worked well for hot restarts (very well actually) and heat soaking issues. My AFR stayed rock solid. It even wasn't bad with temp swings at low RPM/load.
    The biggest issue was how far it ended up being off in large temp swings in the same day. I actually just put the IAT back in and am working on some other things now that I have that information. To really make use of it, I need to put a 2002 OS in my car so I can adjust the bias. That coupled with the data I have from a steady IAT should help build a reasonable bais table.
  19. #199
    Jul 2005
    arkansas
    530
    Just did this on my tahoe. I had to add an awful lot of fuel to even get the wideband to come off of 16 (ngk). Took a nice long drive to pick my son up, just babying it along. Open the log and the damn map sensor didn't regester on the log what so ever!!! But it's below 70° and it actually had a steady rolling idle finally. It's going to get even colder tonight so I will see what happens.
    '04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, Circle D triple disc 3,000, FLT LVL 7 4L60E, L92, 227/235 111lsa.
    Old 5.3=12.33 @110mph
    http://www.streetfire.net/video/turb...mph_741849.htm
  20. #200
    Advanced Tuner sarg's Avatar
    Aug 2011
    Atlanta, GA
    305
    Found this searching. Is there anything that can be done with the 2000 z28 os to help this? Running 3 bar sd and see some stupid swings.
