Results 1 to 8 of 8
Thread: 411 PCM Into 99 Silverado
    Mar 2011
    Idaho
    29
    So i have this kid that put a '02 tahoe pcm into his 99 silverado. i turned the vats off and it runs, but its in reduced engine mode. the truck is obviously cable throttle and going through the tune shows its ETC. Was throwing codes for it too. Anyone know off the top of their heads what needs to be done to get this thing out of reduced engine mode? segment swap or something?
    13,565
    Don't quote me on this but if that computer has IAC drivers you can make it run the cable TB.
    Otherwise you must install a DBW throttle body/engine harness and pedal assembly to match the computer.
    If it was me I'd just grab a 01-02 silverado cable TB computer any put it in that truck.
    Mar 2011
    Idaho
    29
    man that would suck. well heres whats in that pcm
    Advanced Tuner Obsolete489's Avatar
    Feb 2017
    Yankton, SD
    299
    Does the 99 have a 5.3? I think you could do a complete flash with an OS that was meant for DBC then tune it for the 5.3, that would probably solve the issue?
    I'm confused why he bothered swapping the 0411 into a 99 silverado. This isn't a c/k series truck is it?
    2000 K2500 - 489 CI Vortec w/ comp XE270 cam - 0411 swap and rear mount turbo
    1972 M35a2
    2011 LML Duramax
    Mar 2011
    Idaho
    29
    the 99 has a 5.3. I found a 02 silverado file that i think has DBC and did a segment swap and transferred everything that was important from a 99 into this 02 pcm like IFR, VE, MAF, SPARK ect.. im going to write it and see what happens.
    the reason was because he had a superchips program on it and was putting it back to stock and pulled the cable before it was done finishing and supposedly bricked original pcm. his buddy had the 02 tahoe computer lying around so thats what im dealing with lol
    Feb 2017
    Yankton, SD
    299
    Okay, that makes more sense. I don't see why that wouldn't work, hopefully you can avoid having to waste the credits to write a different OS onto that ecm. Let us know what happens.
    1972 M35a2
    2011 LML Duramax
    Mar 2011
    Idaho
    29
    alrighty well i uploaded the new tune with everything i said i did in post #5 and i worked great. no more reduced engine power and it runs perfect!
    Feb 2017
    Yankton, SD
    299
    1972 M35a2
    2011 LML Duramax
