Results 1 to 5 of 5
Thread: TUTD 6L80e question
    TUTD 6L80e question
    I recently installed a PCS paddle shifter in my truck and with my tune that was currently in the truck I could not get the shifters to work. After some playing around, I found a TCM in my shop with the same OS as the TCM in the truck. I read it out and flashed it over my TCM in the truck. Tapshift works as it is supposed to.
    I flashed my original tune back to the truck and compared the transmission data for the TUTD with no luck.
    Is there something in the working TCM data that HPTuners does not show that is allowing that OS to work and my original not to work?
    Tapshift working.hpt
    Tapshift not working.hpt
    Mar 2017
    31
    Any updates on this? It seems there is something HP Tuners is not showing.
    Jan 2007
    LOS ANGELES
    81
    If I am correct , the tune with it not working shows active range in d5 the tune that is working shows active range d4. Assuming when its in drive it means D4
    I am actually working on this myself hopefully I am correct
    Jul 2016
    20
    did you ever figure anything out with this?
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    And what means Range "9" ?
