Black Pontiac Trans Am WS.7- Runs on E85
And soon to be powered by Twin Turbos.
How to run your LS1 on E85
yeah...these are what a lot of people own....myself included
if you look in the EIO stickies..you'll see that I wrote a writeup about hooking an LC1 up to use as a wideband and a narrowband simulator
any wideband that has a 0~5volt output or any range inbetween is ok to use
-Scott -
and all i need is included in those?
Everything is included. You might want to verify, though, that the unit you're buying is the latest model. Apparently, due to many failures, they've changed some components to add ground fault protection. Go to the Innovative's Forum for a long discussion on the failures and solutions. Innovative appears to be a stand-up company that supports their product and buyers.
Best regards,
Bill
Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
