Gents,
We have an 07 Escalade ESV AWD with a L92 418, Ported heads, Gibson shorties, stock intake system, stock exhaust system. Comp VVt Cam 156-400-13 210/224 .556 .568. 114 LSA, Morel lifters, 11.2:1(chambers softened) Comp push rods, trunion upgrade, LS3 injectors.
I've tuned 100's of LT1 cars with datamaster and tuner cat, both SD and MAF tunes. Plus 100's of carb cars. the tuning parameters aren't a new concept and after driving it I can see where the changes need to be made, I just don't know where to go in HPtuners. I've read all the FAQ's, but they are two versions of software behind(and ten years old) what I have installed, and show tables that simply aren't in my file, at least that I can find.
Obviously this isn't a race car, but when it was first built with the truck injectors per the data it was turning all 4 tires on dry pavement. I did buy HP tuners basic and a mail order tune from PCM of NC. We made a couple pulls on the street with the initial tune and stock injectors(intention was to stay with the stock L92 injectors). Unfortunately we were out of injector at 5400, its supposed to shift at 6400. So we swapped in a set of new stock LS3 injectors and had them redo the tune. Since then it has just been far from right and obviously down on power. They have worked the tune 4 times, and it really has zero changes in drive-ability and performance. I give up, I guess that $200 went to money heaven.
So problems I have with the tune.
1. Idle hunt. I've read tons on this and how to fix it, but the tables referenced simply aren't in my tune, at least that I can find. AFR at idles starts nice and smooth, but after 20 seconds or so it starts chasing idle speed, and AFR bounces from high 12s-high 15's.
2. WOT fueling is all over the place. Commanded starts at 12.8, then drops to 11.8, the 10.8.....performance follows this trend. The actual AFR starts perfect at 12.6-12.8, then goes to high 13's, then heads down into the tens. Seriously I don't think I could get a carb to fuel this poorly.
3. Spark drops from 24-10 about the same time the WOT AFR starts going leans, shocker.... you can imgaine to what the power does at this point.
4. They told me this was a SD tune, but for the life of me I can't see how. Is SD even necessary at this level? Its just a little warmed over stock plus the cubes. Per fuel it was making over 540hp, we think it would be close to 600hp the way it rolling now(if we can get the tune fixed). No AWD dynos within a reasonable distance.
It seems I got the cool E38 with no VE table.
I've read about a "MAF disable" selection but I can't find that menu.
Where is the cam VVT table located? I have a sneaking suspicion that this is just zeros.
Any and all help would be appreciated. I am logging the Aem Wideband via AC pressure. Formula used is (2.375*[7101.10]+7.5125) This read right on with the gauge.
I have attached the tune and a log file. In the log you can see the acceleration in first gear level off as the AFR goes lean and it pulls all the timing out.
