No Speed out of 360fly 4k GPS Data in RaceRender?
I am using a couple of 360fly 4k camera with the latest firmware. I am able to get the GPS data to work in RaceRender, but it seems that the only data that comes across is the g-force data. I was expecting to see location and at least speed. I see those on 360fly's demo of using RaceRender. Does speed no longer work with 360fly without the addition of trackaddict?
The speed data should work from the 360fly 4K by itself, as long as its GPS was enabled during recording (you'll need to use their app to do this, and it may reset when you power the camera down).
If for some reason, you have valid GPS data, but are just getting a zero speed, you can opt to have RaceRender estimate the speed from the GPS movement: Double-click on the data file in the "Input Files" list, go to the "Speed" selection, and choose "(Calculate MPH)".
