Hi all,
I'm rather new to the forum and I've been having alot of trouble out of my 2006 Corvette so i thought I would post a few questions here. A while back i had to the crank and stall condtion, chased my tail around and turned out it was VATS, so i disabled it Via HPTuners. After i removed VATS i cranked it and now It has an idle surge, the MIL will come on and the rpms will surge up and then back down to around 900 rpm. I've tried capturing the DTC with no success, i've enabled just about every possible MIL and set it to "first error and ses light". I've even unplugged to MAF to see if it would set the DTC, no success. Even commands such as clutch interlock disable doesnt work, and It wont respond to manually turning the fan on and off through VCM. Is this possibly a bad ECM? Almost forgot, build is a supercharged Iron 408, 243 (Ls2) heads, 2006 Corvette M6
As i said, I'm new so ill try to post the tune and the scan logs i have, but the scan stops logging as soon as the MIL comes on and right before it surges, like the ECM just stops communicating for a spit second. Would some of the pro's mind looking at the tune and see if they see anything crazy? I didnt do the tune, had it tune a while back by a professional. Thanks!
https://www.youtube.com/watch?v=rsKJG-FDl5Q
