Results 1 to 5 of 5
Thread: Another Ls1 hot cam idle help thread
    Nov 2016
    indiana
    6
    Car some times idles fine IAC counts are 60 tps voltage is .55 at 210* have occasional surging and stalling thru out all eng temp ranges and mostly stalls and surges in reverse. any help is much appreciated.
    2001 z28
    1 3/4" headers
    slp lid
    ls1 hot cam
    Feb 2011
    24
    Welcome to the forums.... to get some help, you'll also need to attach a log, and I'm sure someone will eventually chime in...
    Nov 2016
    indiana
    6
    Thank you! will try some data logging this weekend.
    Aug 2009
    Calibrating
    3,373
    If I get time later I'll take a look... for faster response PM me
    Jul 2015
    925
    Fail your MAF and work on the VE. The last hot cam car I did I had the exact same problem as you with it stalling especially in reverse.
    After you fail the MAF I would probably guess that it's pulling a ridiculous amount of fuel out running in SD.
