Looking for tuning discussions,......
From my endless reading,....seems people have conflicting tune parameters/philosophies for 4L60e transmissions with upgrades/shift kits,.....I'd like to test y'all's tune performance suggestions on my existing transmission,....and get it dialed in,....before installing the new Finish Line Transmissions Level 5 4L60e. Then report back findings.
Firstly, my truck is a 1996 GMC K1500 (ground up restored) with a GMPP HT383e, 0411 swapped, 4L60e, 4x4, 6" lift/35" BFG's, with helical Detroit Locker/3.73 gears. The engine/trans has been dyno/street tuned and simply put,..hauls tater (for a 4x4 truck, anyway),....but transmission is going out now,....thus, I'm going with a new level 5 transmission from FLT,... my existing 4L60e is new (only 353 miles on it), and has a Superior shift kit/Sonnax boost valve and beast sunshell, etc,....it's just, I've lost faith in my local builder,.....he's rebuilt it 3 durn times and still got issues.
I know I should do the 4L80e swap, but,....gonna hold off on that till my supercharger install in a couple years/retune them as a pair.
New FLT level 5 transmission has the following;
FLT machined performance pump (also has the Sonnax .490 boost valve)
FLT sleeved input drum
FLT (billet 6061 aluminum) overrun piston
Sonnax SmartShell w/bearing kit
I also upgrade to the - Sonnax Smart Tech input housing (3-4 clutch pack, 8 clutches with Kolene steels)
Eliminating TCC PWM (going strictly on/off)
GM 5 pinion input carrier
GM 5 pinion reaction carrier
Bearing style reaction shaft
New reverse input drum
Alto wide 2-4 carbon lined band with reinforced anchor
B/W hi-energy 3-4 clutch pack
B/W double caged 29 element sprag
4L65 low roller clutch
Corvette Servo
Sonnax super hold 4th servo
B/W clutches
Updated aluminum accumulator pistons
FLT calibrated valve body w/ HD 2-3 shift valve modifications
Stock stall torque converter with an Allison hub/weld reinforced (don't need a higher stall - this engine produces a lot of grunt at low rpm's)
Also installing a Tru-Cool 40k transmission cooler with -6AN lines (eliminating the stock 2nd cooler and radiator cooler - I live in Florida, thus not cold enough to run through radiator)
Seems some people agree/disagree on various posts concerning certain 4L60e upgrades;
- shift times (some say stock, others say adjust)
- torque management adjustment
- some say with shift kit installed - set everything back to stock settings (others say don't)
- torque converter locked/unlocked in 3rd
- larger boost valve installed - set everything back to stock (others say don't)
- lower/raise force motor tables
- etc.
Considering my truck set-up and transmission upgrades, I'd be interested to see what you guys think is my best approach to tuning this sucker?
Thanks guys, I look forward to y'all's comments - I'll tune/test your suggestions and report back findings
