I just emailed a 2017 2.3 ecoboost ford racing cal to support. Mailed another 2.3L ford racing cal in a couple weeks ago. As soon as they are viewable I will put them in the repository.
Do you know which strategy code you're running? Did you turn off all of the "nannies" in the Flare configuration screen?
Load your calibration and then click this box:
Did anyone load a auto Whipple tune?
I think all of the ones that have been posted here are manual.
@Racerbox77 PM sent
Guys after much trial and error I've got my car running very good on my tune. It started as a Whipple tune from last October or so. I'm not going to mess with the latest Whipple tune. I implemented a the MAF Temp Compensation from the latest Whipple tune but I reduced the numbers a little.
I did notice they changed the injector set up slightly but I left it. The car is running very strong and driveability is awesome so until I get a Meth kit I'm gonna leave it.
Can you post the hpt read file from October as well as the latest? (Before you made edits) I may try the same thing, but I'm trying to sort out which file is which while I wait on Eric and Mark.
Does anyone have a Whipple read from a 2017 that was taken before the latest update that messed everything up?
will this read from whipple new tomahawk tuner they told me if I try and read it it will put the car in failsafe and wont be able to get it out of it ?
Didn't put mine into fail safe.
But you will probably have to get [email protected] to define your file (make sure you select the proper ecu type for your year model)
What is your year model?
Eric fixed my 2017 read tonight, have a few issues but nothing related to HP Tuners.
So just to be clear, is HPT able to write over the Whipple calibrations for certin small changes? I have a stage 2 whipple on my 2017 GT, stock headers, cat back, 3.75 pulley. The Whipple calibration was perfect in terms of drivability. Cold starts, idle, all those things were exactly like stock. The only issue I had was slight hesitation at low RPMs under heavy throttle. I brought the car to a local tuner and the slight hesitation is gone but I'm dealing with a few other problems. Bad start, car rolls on after I'm off throttle and the transition into boost at WOT seems kinda choppy. I'm trying to work with him to get this thing figured out. Whipple was almost perfect! Too bad he just couldn't address the 1 hesitation issue instead of writing a whole new calibration for the car
What Eric has done is to unlock the Whipple calibration so that it can be edited. For instance I didn't want the DW injectors, I knew the ID1050x was a better choice and the data is better in terms of accuracy. So I flashed the Stage 2 calibration, read it, sent it to HP and then flashed it to the car with my injector characterization values. Works perfectly. My issues were due to a misunderstanding with Whipple tech and the 2017 TB issues. I'm now playing with the HP version of the Guardian features and its been working very well.
Oh nice. Is the editing limited to certin features only? Would my tuner have been able to adjust what he needed to fix the slight hesitation I was having then? Sorry but I'm very new with this software but I'm determined to get my car dialed in perfectly.
