Can anyone tell me exactly the TCM is located. I believe the PCM is the one under the fuse box on the passenger side.
Thank you
Thank you
Should be inside the transmission on that one - part of the valve body unless I'm mistaken and GM has changed something
~Greg Huggins~
the vette is behind the rear bumper
Thank you all. I found it. It on the passenger side behind the facia. Problem you can not see it because the cooler is in the way. About an hour to remove[ATTACH=CONFIG]68398[/ATTACHTCM Location.jpg
