Results 1 to 2 of 2
Thread: C7 Z06 2016 fuel cut problem
    Hey All,
    I just finished tuning a C7Z A8 with an F1X. I feel the cam was not optimal, but we made about 1000whp through the auto. The vehicle is using a supplemental fuel system through 8 port injectors in the procharger intake manifold. The supplemental is done through it's own computer, and here is the problem :
    When the vehicle rev limits, OR changes gears during WOT, it turns off the fuel injectors. The port injectors at wot will still be flowing and this will cause a terribly lean condition. How can I make sure that the torque management event for the shift, or limiter will only use spark, and not fuel cut? Any help is much appreciated.
    I have not tried to drive the car yet during these conditions as I'm worried that even one event can cause damage.
    Tuner 9secZO6's Avatar
    Sep 2007
    On the Bayou around New Orleans
    82
    Have you found a solution to this yet? I believe that with fuel flowing during a shift the trans will see higher than commanded torque, and that would be bad as well.
    06 Z06 ETP heads, 244/256 hyd. roller, crower stainless shaft rockers, Kooks stepped race headers,elec. w/p, 160 stat, vararam, ram dual disk, ported intake and t-body, 100 shot spray until the 441 goes together http://www.youtube.com/watch?v=fm1hrBcq63U
    2016 Callaway Z06 a8 3lz zo7
    Heads, cam, headers, 2.3L s/c, 9.5 lower/2.625upper, meth, 103mm t-body,
    Stock high and low fuel system for now (I know right?)
