I sent a message off to Chris, never got a reply.
E38. Jump into PE random lean spike between 2.1 to 2.3 seconds.
Questions for others:
1. Have people only noticed this on pre-2010 vehicles? (the they have a much weaker fuel pump and settings).
2. Has anyone noticed this on the stock cam or is it only after a cam swap?
3. Has anyone noticed anything? pressure drops, voltage drops....
4. How much timing is everyone running.....
5. Only been after you've pulled the fuel rail up/changed injectors? I even replaced my original o-rings.... didn't help.
I don't know what else there is to ask. I feel like maybe HPTuners is missing some stuff for the E38's that could fix this...... some missing features somewhere, or time limits etc.
It doesn't seem to have anything to do with how peoples cars are setup, maf or mafless etc........ before I did my cam change to a LS9 from the stock L76 there was a very minor leaning out at 4800rpm 6%..... that I could never get rid of. But now with the cam change it's massive right on 2.1 seconds any rpm after PE engages. Is there a PE bug or setting we are missing?
It doesn't appear to be injector timing, VE related......... could be voltage, mis fire, power loss, transients (maybe some setting we are missing)...... we cannot log on the scanner when transients start/end properly.
It's a very big issue......... basically you cant do a single dyno run...... and it risks engine safety.
