Results 1 to 3 of 3
Thread: Little help getting L83 started
    Feb 2017
    2
    This is a conversion. L83,ECU,6L80 out of same donor. Does not have FPCM fitted. I am not seeing the injectors opening in the scanner. I did get it to fire on starting fluid. It does have a stock Fuel Line pressure sensor fitted just after my regulator. Any help is appreciated.
    Red
    Mar 2016
    14
    did you tell the ecu that a fpcm is not fitted, along with the other required settings?
    Feb 2017
    2
    I did select the FPCM as not fitted, disable Vats, starter diag, and clutch. If there is anything else I probably missed it.
