I am new to the HP Software where can I get a list of the supported wide bands that will work with the HP system ?
The ones in the picture have the data already in the hp tuners scanner for you but you could use any other wideband sensors as long as you are provided with the voltage offset and other components of the formula. So if you buy a wideband that's not on there, you would just make your own input for a wideband with your own numbers.
You can input the parameters of the wideband yourself.
I used this video to set mine up, you can also fix the error by adding or subtraction the amount of error between the car/dyno widebands
https://www.youtube.com/watch?v=jMalD15mOg4
