Hi guys,
Appreciate you taking the time to give this a look. Here is the situation:
Car: 1963 Nova
Engine: 2003 5.3 LM7
Mods: 224/224 TSP cam with 110 LSA + spectre cold air intake (also changed valve springs for higher lift cam), shorty headers
Trans: stock 4l60e
Converter: 3000 stall
DTCs:
- Engine RPM output circuit (i'm running a Dakota digital dash unit and don't have it hooked up yet so i'm not concerned about this DTC)
- System lean bank 1
- System lean bank 2
I'm thinking I have a vacuum leak somewhere that is causing the lean conditions but i'm no expert. I don't believe the wideband readout is accurate in the log file...long story short i'm using an ASPX WB and I don't think I set it up correctly in HP tuners. I've attached the log file and tune file. I had a friend help with the tune. I should note that this log file was started after I had the car idling in the garage so that explains why the temp is up at start.
first drive - lean.hplWes Stock 63 Nova Tune Idle Speed 40% PE & IAT added KPA fuel.hpt
Again, appreciate you guys taking the time to look this over and offer any suggestions.
- Wes
