Hey guys, looking for a little help here. Got a 2014 Corvette with headers and a P1-SC that was tuned somewhere else. The shop sold him a tuner kit since they have an in house tuner, so no base M7 procharger tune was included. This guy was a previous customer of mine, but I told him I wasn't 100% on the DI stuff, so I recommended he find someplace out of town that he felt good about. I'm not looking to embarass anybody here so I'd prefer not to mention who did the tune.
The primary concern the customer has is that when he rolls into the throttle, around 4,000rpm the car "shuts down," then comes back alive and finishes the pull. I told him I was 95% sure it was related to the throttle body closing, but after playing with the DD, peak torque, and PE enabler settings I can't really get anything resolved.
For the DD table, I tried smoothing the top few rows up the table into the lower TP% rows. No change. Set back to previous settings.
For the peak torque, I tried setting it to a stock procharger canned tune settings, plus 10% ballparked for headers. No change, set back to previous settings.
For the PE enable settings, I lowered the setting so it would kick into PE around 2,500rpm to make sure it wasn't a fueling issue. No change, set back to previous settings.
The only thing I didn't play with yet is the virtual torque tables, but given what it's doing I can't see them being the root of the issue.
Now on to the attached files...
I know the peak torque setting is not set right, since it is not a limiter table as the previous generations.
I know the MAF table looks a little funky. I have not hooked up my wideband on this car, as I felt I was really hunting for a throttle issue.
This car has a known issue on one bank which shows its head on the oxygen sensors, which resulted in turning off the LTFT's (which I did). Otherwise one sensor would max out fuel trims and need them reset every couple of days, or the car would obviously run poorly.
I found I had to modulate the throttle a little around the 4,000rpm range to get the issue to show itself. The next to last "pull" on the attached log is where it finally did it.
I've attached the original tune and a scan file from that tune, if anybody with some experience can lend some insight I'd appreciate it.
