All else being in order, if a 58x Gen IV motor had an LS6 cam installed and the installer used a 1x cam gear instead of a 4x, would the motor even start?
77 C10 - 416 6L90e Swap
It might burp but that about it, more than likely anyway.
Thank you, I must have the right cam gear installed them.
