Results 21 to 40 of 44
Thread: Still won't shift @ WOT without hitting the rev limiter
  1. #21
    Tuner Monty's Avatar
    Apr 2012
    173
    Sorry guys when i uploaded the tune file, i totally double clicked it thinking i was unlocking it, but it was already unlocked haha .. neways its unlocked now, so here ya go if ya need it... peace
  2. #22
    Apr 2012
    173
    Quote Originally Posted by LSpowered93 View Post
    That didn't help with my issue. I still can't open the one you posted, nor the one that 10SecSleeper posted.
    Maybe you need to update your Hp tuners version, im running 3.4.. Sorry i don't know this error
  3. #23
    Apr 2012
    173
    When I try to open his file I get an error message that says "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the "VCM Suite disk and click ok."
    Sorry man i don't know this error
  4. #24
    I figured it out. For some reason my laptop uninstalled HP Tuners. Very odd.
  5. #25
    Quote Originally Posted by 10SecSleeper View Post
    Have you in fact swapped from the stop 3.08 gearing to 3.73?
    If so, give this a shot.
  6. #26
    Appears it might be slipping, as in needing a rebuild. If you do it yourself it can be quite cheap. I used a old clothes drier that was set out for scrap. Cut a hole in the top of it for a drain and a second hole to hold the shaft. Then put shelves in it to hold parts to keep them organized.
    In the log it's shifting at 5700, but doesn't stop revving till 6300.
    Then again it might be a tune issue. Make sure it has the correct tire and gear setup in the tune.
    Persistence is the key to success
  7. #27
    Tire and gear seems to be spot on. I was thinking it probably needed rebuilt myself until I tried the tune that you edited and now it shifts to 3rd flawlessly. That makes me think that with a little more tweaking, the 1-2 could improve.
  8. #28
    Refer to the white line, it represents the current gear. You can see it shows it as shifted yet rpms continue to rise. While in first gear it takes quite a while for rpms to transition to what would be considered normal with the gear engaged fully.
  9. #29
    Advanced Tuner IARLLC's Avatar
    Aug 2016
    943
    A stock trans in decent condition will shift decently with a stock tune. Once there is significant wear raising the pressures will increase holding power and crutch it up a bit....but it does not mean that it is in decent condition. It will still need a rebuild before it begins to work properly again.
    Have seen a few times when the pressure control solenoid (force motor) screens were plugged up allowing enough volume and pressure for decent light throttle shifts but slipping badly under heavy throttle shifts...but why were the screens plugged up? Clutch material....still needed rebuilt.
  10. #30
    What I'm looking at is where it doesn't even begin to make the 1-2 shift until almost 6300rpm, where current gear changes from 1.0 to 1.1. I understand slippage, but that doesn't explain why it isn't even attempting to change gears until 800rpm after the computer tells it to.
  11. #31
    Well as the post just before you mentions... "pressure control solenoid (force motor) screens were plugged up". I've seen this happen, You can get a mechanical gauge to verify you have this issue. It should be around $35. You will be able to see what the actual line pressure is.
  12. #32
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Thats the point. Once the pcm commands the shift, it should shift. If pressures are good, and it continues another 800 rpms before shifting, then you either have a hydraulic issue, or a clutch issue, i.e., there has to be a massive volume of fluid applied before the shift happens. When good pressures and shift times are in the tune, and you see shifts above 4-500 rpms, its rebuild time
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  13. #33
    May 2017
    9
    before you start tearing down the transmission I would copy a stock transmission tune and save the new file as (trans test) or something so you don't confuse it with your current tune file and upload it and see what the transmission does then. If it corrects the problem you know it's the tune, if it doesn't then it's the transmission.
  14. #34
    May 2018
    5
    So I have a 2014 Silverado and swapped from 3.08 to 3.73 and with a Speedo calibrator installed it won?t shift under wot, just bounces off rev limiter, wen I take the time out it?s fine. What do I need to do thanks
  15. #35
    You need to adjust the shift speed(mph) in the trans settings. With the 3.73, you aren't going fast enough in each gear to meet the speed requirements to perform a shift at wot.
  16. #36
    May 2018
    5
    So how would I go about that?s is there a calibabrator to buy or can a shop do it.. will a hyper tech Max tuner do it by switching the shift points???
  17. #37
    May 2018
    5
  18. #38
    Just by your presence on this forum, I assumed yup have an HP Tuner. A handheld device should be able to fix it though, but I'm not sure, personally.
  19. #39
    May 2018
    5
    So I had a Speedo calibrator from hyper tech and that would only do tire size and gear ratio so I got the hyper tech max which does all, just don?t know if it will change wat I need, wat do u think. Does it change way I need? Thanks
  20. #40
    I know this is an old post, but I am having this issue as well. hell even zero'ed 1-2 and 2-3 and still nothing now I am going to try matching the part throttle shift time mph to the wot shift mph and see if that helps
