Results 1 to 18 of 18
Thread: 2015 f250 6.7 limp mode any ideas???
    Nov 2008
    Tampico Bay, Mexico
    172
    first attemp on this plataform and already regret to do it ....
    i download some stock and hotter tunes to take a look and see how its made and from the first few changes everytime i roll over the throttle it goes to limp it sets p061A DTC i try going back almost on any table and keep doing it so last night i give up and load the stock tune again but i need this truck tuned so please take a look maybe im overseening this trouble
    all the way from Tampico bay Mexico
    Jul 2016
    46
    i cant open your files since the bin is missing??
    Have you seen this post? It seems informative. https://www.ford-trucks.com/forums/1...de-thrown.html
    Nov 2008
    Tampico Bay, Mexico
    172
    what is the number that you dont see? you have to opened on beta
    Quote Originally Posted by ancientcitycustoms View Post
    Jul 2016
    46
    Quote Originally Posted by dlc_racing View Post
    Ah i don't have the beta yet. that would explain it.
    Jul 2016
    46
    Quote Originally Posted by gilgamesh View Post
    Did this help OP? I didn't see anything abnormal in your file that would throw that code. You running stock intake?
    Nov 2008
    Tampico Bay, Mexico
    172
    Stock everything ... just playing around and i narrowed to the fueling tables ...any time i command more main injection quantity i can run the truck for about 5minutes and then when i roll over the gas pedal or make a power downshift it just stall and blinks the wrench light on the dash and set the dtc p165a..(internal torque module performance)
    Nov 2008
    Tampico Bay, Mexico
    172
    Now im out of DEF and it flashes on the dash that my particule filter requires clean up😅
    Jan 2015
    214
    Im having this problem when modifying these exact tables. 2017 6.7. Did you find a work around?
    Nov 2008
    Tampico Bay, Mexico
    172
    Quote Originally Posted by reubone View Post
    im still on the same trouble i think is related to the fuel pressure droping to much now i have two dtcs P0087 fuel rail system
    to low and the infamus p061A internal control module torque performance im gonna log the rail pressure cause it only fault when i smash the throttle under part throttle it works flawless the truck now it have a DPF delete and a "X" brand handheld tuner and it does the same crappy thing
    Advanced Tuner JaegerWrenching's Avatar
    Jun 2018
    Albuquerque New Mexico
    239
    What software are you using with the DPF deleted? Are you using two different tuning software's?
    Nov 2008
    Tampico Bay, Mexico
    172
    Yes i have s[t handheld over the stock just for the dpf delete cause HP doesnt mess with emmisions and HP for the detailing and performance
    Jun 2018
    239
    What sct tune are you using to delete the dpf? i'd like to do this myself.
    Nov 2008
    Tampico Bay, Mexico
    172
    i have to buy a handheld from them to make the dpf delete ...in the tune it doesnt show anything ...thats suposed to be cause the changes are on the binary file not on the part that we can see or edit on HP tuners sorry for that
    Jun 2018
    239
    Anyone figure this out? i think i'm having this issue but my P061A code is shut off, so it just goes into REP and then nothing is on the screen but it's still in REP mode.
    Jan 2020
    1
    Quote Originally Posted by JaegerWrenching View Post
    Jun 2018
    239
    The solution is torque table related.
    Jul 2019
    Florida
    114
    I recently found an old sctx3 I have the X4 you must of had unlocked tunes or am I missing something would be a nice work around as far as limp mode that?s my middle name Mine was mono mode holding fueling if there is a place to increase torque I set to 1033 or 1106
    I didn?t see your tune posted but I?m on a cell phone
