need help ls1 camaro keeps hitting rev at 2-3 shift wot
hey guys looking for a little advice im new to hp tuners an I believe I have a common issue I just need a little help getting around it .. the car I have is a 98 Camaro ls1 with 4l60e 60k miles on it .. didn't start doing power adders until 55k,... has all bolt on power adders and I just installed the hd2 kit from pro built automatic an a new yank ss4000 stall.. 1-2 shifts spot on at the commanded rpm and mph but my 2-3 is not I keep hiting rev .. engine rev limit is set at 6300 .. the 2-3 shift is set at 5900rpm an 61mph ... before I installed shift kit an converter with just the bolt on tune it would spin tire going into 3rd can someone shed some light on my issue. thanks in advance
Reason: spelling
How about a scan and a tune
Mine was doing the same thing in a 99 silverado with a built LS1, but ended up being the 3-4 clutches were done. Hope that's not the case for you.
