Results 1 to 10 of 10
Thread: Sensor to log FP with MVPI Pro?
    May 2006
    Lebanon, IN
    4
    Any suggestions on a sensor I can get to log fuel pressure on my 2003 Grand Prix GTP through my EIO? I assume I would need an adapter to hook this sensor up to the schrader valve on my fuel rail and then run the wires in and connect them to the EIO. Also, I assume the voltage curve would not be linear so how would I figure out the proper formula for the scanner?
    May 2006
    45
    A bit of googling brought up this one, that's a cheap price. It should work. And you will probably need a pipe fitting.
    http://www.jumousa.com/xcart/custome...cat=283&page=1
    May 2006
    Lebanon, IN
    4
    That sensor maxes at 60 psi, I don't think that will work.
    May 2006
    Lebanon, IN
    4
    They also don't have a 0-5V output to connect to the EIO. I appreciate your help, but I was hoping I could get some input from someone who has done this. Specifics on sensor, adaptors, and the voltage curve to get an accurate reading.
    May 2006
    45
    To convert 4-20 ma to 1-5 volts will require one 250 Ohm resistor.
    Of course, if anyone else has done it, perhaps they will chime in. If not, I can probably help you.
    --97T--
    Apr 2003
    Almost 2000 feet.
    7,876
    Instrumentation grade: THIS one might work as well.
    Commercial Grade: Check HERE too.
    Always Support Our Troops!
    SeƱor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    I'll be hooking up an Autometer FP gauge as soon as Speed Inc gets me my fuel line, and tapping into their sender. I've been told it has a linear output, so I'm going to try and relay that to my EIO. I'll let you know how that turns out.
    2008 Viper - now with HPToona - 1/4 Mile Shenanigans Here
    11.02 @ 130
    Nov 2002
    Central Florida
    2,503
    I rigged an electric sender and gauge to my Actron
    mechanical w/ Schrader. At one time I had the sensor
    info but I'm far from home at the moment. I'll take a
    look at it for P/Ns when I get home but I do recall
    it is, there is a pretty standard sender. Don't know
    what the characteristic is as-wired, the gauge does
    that housekeeping, but I bet there is something
    worth tapping.
    Mar 2006
    West Lafayette, IN
    95
    Use a stock oil pressure sensor - already an NPT fitting.
