Results 1 to 13 of 13
Thread: 2017 Camaro 2.0 Turbo support
    Tuner Ls3sierra406's Avatar
    Jul 2011
    Texas
    51
    What is eta on support for 2017 Camaro 4 cylinder Turbocharged?
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by Ls3sierra406 View Post
    Has been supported for a while. Please e-mail support and request 3.5 beta.
    565
    Is it only supported with the beta? I ask because my beta link keeps disappearing from my customer page.
    May 2006
    Seattle, WA
    539
    Quote Originally Posted by reubone View Post
    You need to re-request access to the Beta every 30 days, it will disappear from your customer page after that 30 day period until it is re-added by support.
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    Jul 2011
    Texas
    51
    Thanks will do that I have Beta but guess not most recent
    Quote Originally Posted by ScarabEpic22 View Post
    Thank you will ask for latest beta
    28,272
    Yes, only in beta.
    Advanced Tuner lt1z350's Avatar
    Mar 2014
    Dandridge, TN
    560
    Tuning a 2016 now and responds so much better then ats did when tuning. Making some redicilous torque on it already with tune only on 93.
    First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
    2013 cadillac ats 2.0t Big turbo-gone
    2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
    2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
    Dec 2016
    6
    Quote Originally Posted by lt1z350 View Post
    I am in the process of tuning mine right now. Any tips on the tune? How to adjust boost, what afr it should be seeing, timing on 93 octane, etc..?
    Mar 2014
    Dandridge, TN
    560
    If you want a log and my first tune I did for him I can post them that way you have a good starting point. Timing is tricky on these as they are prone to false knock and most I have tuned had a down pipe on it all ready before I started adding any timing to it. When had a stock cat still I just smoothed the high table and added 1-2 at most in places to accomplish a better table then matched the low table to it then add a buffer of 4 degrees from 1.0g and up. Does you car have the boost gauge on it? If so what are you seeing stock for boost? I have a feeling the pid is off for boost as this car is seeing 26 lbs at times and know my older ats struggled at 24 lbs and to see this camaro make 26 doesn't add up as they claim the same motor still from 2013.
    Sep 2006
    Arizona
    600
    Feel free to post it up if you want. The Camaro does easily hit 26psi. As for the false knock you are seeing, it may be because you are exceeding your Airload Knock Limit or whatever. It uses KR as a means to combat commanded boost when you exceed the programmed amount of g/sec at that RPM and current real knock amount.
    I'd be interested in seeing that as well. I have a '17 Buick Encore 1.4L turbo that's a real dog and could use a little help. It's supposed to have a faster 0 to 60 time than my Volt, but you wouldn't know that driving it.
    Dec 2016
    6
    Any reason why my base advance would be way higher than what the car is actually seeing at idle??
    Dec 2016
    6
